some electrical help needed please
1.2K views 10 replies 4 participants last post by  wt40
hi can anybody tell me where i can find an ignition live under the bonnet as i'm finding it hard to find one, trying to fit some led lights. cheers:chewie:
What engine and gearbox do you have. They vary in the fusebox.
It's actually a very useful question and one that many people would like answering. We really ought to have a listing of recommended ignition-live points for all the variations. I might start a thread on it.
TC
In mine (Mk 2 1.8T) I found Fuse 2 (that's the one at top RHS in the UB Fusebox) is live with the ignition on.
The different years/engines/gearboxes seems to mean the fuses are used for different things, so a list would be very handy.
TC
#4 ·
Live
On the DIESELS you get a feed which is only live when the engine is started and which turns off about five seconds after the engine is turned off if you take if from FUSE 4 in the underbonnet fuse box. This is the 15A fuse 2nd down on the right. Very useful for LED running lights.
That's for a diesel with cruise control according to my Handbook (??)
TC
The engine compartment fuse panel is the same for all models, although some of the circuits connected to the different fuses, and the fuse ratings, can vary according to the different model.
Fuses 1,2,3 & 4 are switched with the ignition.
From the manual:
Fuse 1 - All 15amp
KV6. Heated Oxygen sensor, purge control valve, crankshaft position sensor, balance valve.
1.8. Same as above, less the balance valve.
M47R. Engine control module, glow plug ECU, CMP sensor, fuel pressure sensor, EGR regulator, MAF sensor.
Fuse 2
KV6 (w/o traction control) + 1.8 - 20Amp
Fuel Injectors, ignition coils, ECM.
KV6 with traction control - 30 Amp
Same as above plus traction control.
M47R - 30Amp
ECM.
Fuse 3 - 15Amp
KV6 + 1.8 - Heated Oxygen sensor, Camshaft position sensor.
[nothing shown for M47R]
Fuse 4 - 15 Amp
All models
Cooling fan, compressor clutch relay, auto transmission selector, cooling fan relay, reverse light switch.
