Hi All,
My newly acquired ZT makes a sloshing fluid sound sometimes on startuop but also when revved gently from tickover at idle. Any ideas what this might be? Coolant level seems fine and fan seems to cut in and out o.k (i.e isn't on all the time).
Cheers!
Hi, Don't think its the Air con as I know what that sounds like from my 75. It sounds like more than that (more fluid).
Someone has suggested its the coolant in the heater matrix. Thoughts?
Found some stuff under gurgling!
Hmm. Seems a few have this then... I was thinking about getting it vac-filled but I don't think the coolant has been changed since new so it should be as ex-works, i.e shouldn't be anything other than the original vac fill.
Maybe I'll just keep an eye on it...
Is the temp gauge capable of reaching Red on a KV6? My 1.8T didn't seem to be abel to go further than Normal hence the suprise when the gasket went
