1955 MG TF & 1975 MGB and 1954 Austin Healey BN 1
Does anyone know of the MG TF 1.8 VVC MOTOR timing marks. Thank you
In English.
Sent from my CPH2173 using Tapatalk
Which engine in english is the 1.8 VVC MOTOR
Is it the 1250 CC or the 1500 CC?
If my guess is correct that top dead center is the same for both,
then consider the following.
.An indicating arrow is fitted on the timing chain case and a hole is drilled or a groove
is cut in the outer face of the crankshaft fan pulley.
Turn the engine until the hole or groove in the pulley in in line with the arrow on the cover
for top dead center on No. 1 and no. 4 cylinders.
A 1.8 (Litre) motor is 1800 cc (cubic centimetres).
Use Google to search for the location of the timing marks and many instruction videos.
