Side indicators not working? is it MOT fail?
15K views 11 replies 5 participants last post by  Cougar888
Hi guys
I noticed the other day my side indicators don't work :( Any ideas why this could be? Its not the bulbs as they are new and came with the clear indicator covers. Is it an MOT failure if they don't work?
If you are going for an MOT take them off. They cannot fail you if they are not there, as long as your front and rears are working. Have you investigated why they don't work? I would be suspiscious that some body has fitted them inscorrectly. There should be nothing common between the two side indicators as they should have a seperate supply and earth. You need to do some voltage checking and continuity checking on the earths.
I'm not sure they worked when i bought the car. I fitted clear indicators recently and found they didn't work. The right side had what looked like grease all over it so i'm guessing that one had a leak which may have damaged it. No idea about the left side though.
#4 ·
Not 100% sure but I thought the side mounted repeater indicators became mandatory after a certain date so will be required for the MOT :dunno: .
Might be just a case of a broken wire or bad connection behind the wing?
I think the grease you refer to is quite normal, sure mine are like that. It's there to protect and prevent moister ingress into the unit.
According to this site the indicators are not required.
http://www.ukmot.com/1-5.asp
But according to that site? -
Vehicles first used on or after 1 April 1986 These must be fitted with one side repeater indicator on each side. Instead of a separate lamp, the side repeater might be part of the front direction indicator if it includes a wraparound lens. Lamps incorporating a side repeater are marked either with an 'E' mark in a circle or an 'e' mark in a rectangle above which is the number 5. c. the flashing rate Note: it may be necessary to run the engine when checking the flashing rate c. does not flash 60 to 120 times per minute d. that every direction indicator emits amber light, except vehicles first used before 1 September 1965 where both front indicators may be white and both rear indicators red d. does not show light of the appropriate colour
YES CORRECT! side repeaters have been UK LAW for a long time!! but however not in europe until a few years ago, their was a time Fiestas,escorts,sieras and granadas sold in europe would have a little badge as a blank to cover the hole in the wing!
Well just been out, came back and thought lets put the hazards on and see whats going on... both side indicators are working, very strange. The self healing car strikes again, i have my own Chitty Chitty Bang Bang :D
