Whether a car exhibits understeer, oversteer, or neutral steer is a function, ultimately, of the balance between the vehicle's front and rear grip.
Tyre grip itself is a function of Co-Efficient of friction, Vertical Load applied (as a result of weight transfer) and Slip Angle. Tyre grip itself is merely a measure of the amount of accelerative force that tyre can generate, whether in forwards acceleration, rearwards (ie braking) or transverse (ie cornering).
The levels of acceleration that any given tyre can produce in any given direction can be plotted onto a graph producing what is known as a 'Traction Circle'. If the tyre is operating inside its traction circle then it is gripping, cross the boundary of the circle and the tyre is no longer gripping, but has started to slide. Thus, for eg, at maximum forward acceleration there is no grip available to develop any sideways acceleration and vice versa. Therefore it is possible to accelerate using throttle and corner or brake and corner (known as 'Trail Braking'), however it is a matter of
balancing the fore/aft and sideways accelerative forces. This is what racing drivers do because it minimises the amount of time they are off the throttle - the problem is that most road drivers do not have the requisite level of driving skill to achieve this balance.
When a tyre is developing a cornering force, for reasons that are beyond the scope of this post, it actually has to develop a 'Slip Angle', ie the angle between the way the wheel is pointing and its actual direction of travel. As this slip angle increases so does the tyre's level of grip at a proportionate rate up to a maximum value where 'Breakaway' occurs.
So, in the case of understeer, the front wheels are producing less slip angle than the rears, therefore less grip, and, hence, the nose of the car runs wide. In the case of terminal understeer (such as locking up the fronts) then the front tyres have reached the break away point (remember the Traction Circle) and the car ploughs on in a straight line until such time as it has slowed sufficiently to regain grip, or you have run out of road and hit something.
In the case of oversteer the opposite applies, the rears produce less slip angle than the fronts, hence the tail starts to come round. Do nothing here and ultimately the car will spin.
Understeer is, therefore, a
stable condition, whereas oversteer is an
unstable condition. It is for this reason that road cars are generally set up to understeer (FWD cars are more notorious for understeer because the front tyres which develop all of the steering effort and most of the cornering effort are also those producing all the forward accelerative effort). Understeer is seen as safe for the average punter because if the driver mishandles the controls the understeer will merely continue, if they (as most likely) back off the throttle sharply, or (to an extent) brake then the car will come back into control.
Oversteer, on the otherhand, is seen as unsafe because, if you do nothing, or (worse) mishandle the controls then it will get worse, ultimately resulting in a spin. RWD vehicles are more prone to oversteer in poor conditions for 2 reasons:
1. Power oversteer. This is the most common form. To much power is applied to early. Since the power is applied at the rear wheels they reach the breakaway point earlier than the fronts.
2. Lift-Off oversteer. One of the factors affecting the grip level that a tyre can achieve is the Vertical Load applied to it. When ever a car acelerates, brakes, or corners then weight transfer occurs. In this case, coming off the throttle suddenly causes a forwards weight transfer, so there is less vertical load applied to the rear tyres so there grip is reduced and oversteer occurs.
Remmie said:
The problem with a midengined car is that there is more mass in the back, so once you're oversteering, it's harder to correct. The weight distribution however enables you to enter a corner faster, which I wouldn't do on the public road, though.
I'm sorry but that is totally inaccurate. The front/rear weight distribution is not the sole factor here, but the 'Mass Centroid Axis' and the moments about it. A mid engined car like the F/TF has its mass centroid towards the middle of the car giving it a low 'Polar Moment of Inertia' (PMI). This results in a car that is more nimble because, owing to the low PMI it will not resist direction changes, and will turn in to corners faster. This is why all real purpose designed race cars have been mid-engined since the early 1960s. Even Formula cars have a slight rearwards weight balance because it aids traction.
Take a car with a similar weight distribution overall but with a mass centroid(s) towards the ends of the car and it will have a high PMI. This will make it more stable but ultimately less nimble.
The very fact that a low PMI car will change direction fast means that if you get it oversteering and apply the correct amount of opposite lock in time and take the lock off as the oversteer ends then it will come out of the oversteer/spin extremely quickly. What catches most people out is they don't take the lock off fast enough and end up spinning in the opposite direction.
With a high PMI car, while it is more resistant to spinning, once the spin has started, it is far harder and takes far longer, to get the spin to stop.
