1 - 2 of 2 Posts
started car up.tick over for a few minutes.splutterthen die.restarted running on 3 plugs by the sound of it.got 100 yards,car die.will not fire up.put sparkplug in end of coil lead that goes to disb.start engine sparking ok.then put sparkplug into each ht lead in turn.then connected up coil plug to no1 lead.engine fired.did the same for other three.or shows signs of starting engine.put coil plug back on disb.no life.being bank holiday can not get to the halfords department until monday.check rotor arm,doesn,t look all that good.disb cap seems 2 years old.hoping that it is the rotor arm knackered.any other suggestions.like timing belt slipped a tooth.thanks
1 - 2 of 2 Posts
