61 - 70 of 70 Posts
· Registered
I have just got round to doing this. For what its worth I reckon the problem isn't with the switch, it is with the connector just like the yellow airbag one under the seat. Before buying a new switch I would try cleaning the connector with WD40 or similar.
Paul
· Registered
rover_75
Where can i bye a reverse light switch for a auto rover 75??????
Hello,
My Rover 75 auto diesel 2001, reverse lights have stopped working and gear select light have also stopped, also when i first pull off the car snatches. Only started when lights packed up...Can anyone help thanks..
P.s where can i bye a reverse light switch for an auto from..????
· Registered
hi everyone my switch has gone i believe no reverse lights or beeping from sensors wont to have a look at doing this myself and just wondered if the location on the v6 manual is any different at all? and someone mentioned it being accessible without taking wheel of is this right? and what the hell am i looking for lol many thanks richard
· Registered
mg_zt
Reversing Light Switch
No you will need to remove the Left hand front wheel, the switch is located on the back of the gearbox, you will need a 19mm combination spanner, I think. it's easy enough if your a competent home mechanic, I found the hardest part was removing the connector.
· Registered
rover_75
Hi, I discovered my reversing lights were out and bulbs were okay so I sought advice here and it's been great in pointing me to the switch only to discover mine was completely disconnected. After a bit of groping around the area, I found the cable, connected it up and, hey presto, reversing lights came on. However, so does a continuous beep. I suspect now that the switch was disconnected when I bought the car to hide this (given other issues I had with the car). I noticed at the time that there were no working parking sensors despite seeming to have them fitted (visually) so could this be the fault...I assume sensors are meant to give out an intermittent beep? Would a new switch fix the issue? Will it cause a problem left as it is (e.g. blown fuses)?
Any/all advice gratefully accepted.
· Registered
The reverse light switch is not the cause of the parking sensor fault, it simply gives the the power feed to the parking ecu, the most likely culprit will be a sensor fault or wiring fault to the sensor behind the bumper.
61 - 70 of 70 Posts
