1 - 20 of 70 Posts
· Premium Member
Courtesy of Chaslee.....
Reversing switch on 75.
Don't follow manual - no need to remove underbelly panel or wheel arch lining and the rest of the bodywork.
Take off near side wheel.
Switch can be seen on gearbox behind suspension spring. 19mm Ring spanner just fits.
Unscrew old and fit new.
15 Mins including having ciggy and sitting back reflecting how short a time it took. Reverse lights now work :)
· Registered
Further help on this please
I have a problem with no reversing lights and will follow the help so far given but what is the fuse number in the passenger fuse box for the reverse lamps? The technical info I have (a CD version purchased on ebay) shows this to be F23 rated at 5 amps - the box does not show this to be so and in fact I cannot decipher a suitable fuse from the pictograms on the fusebox cover.
Many thanks
· Registered
For the 214 i removed the whole airfilter box... disconnected the switch.. dident have a deep enough socket so just stuck a 19 spanner ( i think it was 19.. or 17 ) and it came off not a problem!
Just incase anyone wondered.. its right below the air filter box.. ontop of the gear box
1 - 20 of 70 Posts
