1 - 5 of 5 Posts
mgf
Hi. My 2003 Rover 75 is wearing the rear tyres to the outside.
Obviously this is some sort of alignment problem.
My question is How majour an issue is this and can it be easily sorted out ? Could a man tackle it himself or is specialised tools / equipment required?
Lastly, assuming professional attention is required, does anyone know who or where a Guy in Northern Ireland would take his offending Rover to?
Any thoughts or assistance will be much appriciated.
Banned
This can be solved by getting a 4 wheel laser alignment done. It is a common issue with the 75.
It is essential to make sure you have a full fuel tank when the work is done. Any reputable garage or ATS etc. should have the necessary equipment. Costs around £50 up to £90.
Regards
Mike :)
mgf
Mike.
Thank you very much indeed for your help and advice.
I was worried that it might be a much more expensive job.
Regards.
Nigel
Administrator
I'd probably advise you to stay away from ATS and find a good reputable garage with a proper 4 wheel alignment kit......
1 - 5 of 5 Posts
