Here is how i got my 12volt supply through to my boot on the R75 2LTR. it may save a few headaches and prevent an awfull lot of swearing as it took me 2 weeks to find a way through this darned bulk head, here's a few picy,s of how i did it. firstly remove the 2 covers (one each side) by pressing in the side clips (photo 0001) .
In picture 0002 after having removed the cover you will see a gromet were the bonnet release cable comes through, you can then push your 12 volt cable through here after enlarging the hole in the rubber gromet, you will need to unscrew and drop the cover from the drivers footwell and the side cover behind the bonnet release catch (take extra care with the side cover it has a clip in side and the plastic push in stud at the back) to enable you to see the gromet hole from inside the car (picture 00026).. When the wire is through you can pass it along the channal along side the wiper motor and then through a grommet hole that i found under the right hand cover you will probably need to lift the plastic cover on the right hand side to hide the cable(photo 0003) when finnished you can then run the cable along the door chanelling to the boot.
