1 - 1 of 1 Posts
· Rover Lifestyle
Rover 200 Rover 600
Here you can find positions of Relays and ECUs within Rover 600 cars with Honda engines or Rover engines (petrol turbo and diesel).
ENGINE COMPARTMENT:
A - Power window relay
B - Radiator fan relay
C - Windows wiper intermittent relay
D - Condenser fan relay (Honda petrol engine only)
E - A/C compressor clutch relay (Honda petrol engine only)
F - A/C diode
G - Headlight adjuster unit (LHD)
G - Dim-dip resistor (RHD)
H - ABS motor relay
I - Engine compartment ABS fuse/relay box
J - Test tachometer connector
K - Engine compartment fuse/relay box
L - Dimmer relay
M - Headlight relay
DASHBOARD::
LHD:
A - Engine mount control unit (A/T)
B - Headlight washer control unit
C - Seat heater main relay
RHD:
B - Dimdip relay
C - Dim-dip control unit
D - Headlight washer control unit
A - PGM - Fi main relay (includes Fuel Pump relay)
B - Service check connector (2 -P)
C - SRS unit
D - Rear window demister relay
E - Starter cut relay
F - Integrated control unit
G - Passenger compartment fuse/relay box
H - Turn signal/hazard relay
I - Blower motor relay
J - Radiator fan control module (Honda engine only)
FLOOR:
A :
Engine Control Module
(PGM-Fi for Honda petrol engine
or
BOSCH ECM for Rover diesel engine
or
MEMS Relay module* )
B :
Transmission control module (TCM) for Honda petrol engine
or
Relay module** for Rover Diesel Engine and Rover Petrol Turbo Engine
C :
Key – off operation control unit
D :
Master power window switch
(built – in control unit)
(*) MEMS Relay Module for Rover Petrol Turbo Engine:
- Main Relay
- Fuel Cutoff Solenoid Relay
- Oxygen Sensor Relay
(**) Relay Module for Rover Diesel Engine and Rover Petrol Turbo Engine:
- Condenser Fan Relay
- Cooling Fan Relay
- A/C Compressor Clutch Relay
- Cooling Fan Relay
DOOR, ROOF, SEAT:
A - Passenger's seat heater relay
B - Sunroof close relay
C - Sunroof open relay
D - Door lock control unit (without keyless entry)
E - Driver's seat heater relay
BOOT:
A - Keyless entry and security alarm control unit
B - ABS control unit (Honda engine only)
C - ABS rear fail - safe relay (Honda engine only)
D - ABS front fail - safe relay (Honda engine only)
1 - 1 of 1 Posts
