1 - 9 of 9 Posts
· Rover Lifestyle
Rover 200 Rover 600
Fuse colours
BROWN 7.5 amp
RED 10 amp
BLUE 15 amp
YELLOW 20 amp
GREEN 30 amp
Pre '96
DRIVER’S COMPARTMENT FUSE BOX
Fuse No --- Rating (amps) --- These units not operating
_______________________________________________________
01 -------------- 7.5A ------ Anti-theft alarm
02 -------------- 15A ------- Engine management system
03 -------------- 10A ------- Airbag SRS
04 -------------- 7.5A ------ Cruise control
05 -------------- 7.5A ------ Windows, mirrors and sun roof
06 -------------- 30A ------- Windscreen wipers and washers
07 -------------- 7.5A ------ Heater and heated rear window
08 -------------- 10A ------- Direction indicators and reversing lights
09 -------------- 7.5A ------ Air conditioning
10 -------------- 7.5A ------ Dim dip headlights
11 -------------- 10A ------- Radio aerial
12 -------------- 7.5A ------ Starting signal
13 -------------- 10A ------- Tail lights
14 -------------- 7.5A ------ ...
ENGINE COMPARTMENT FUSE BOX (Export models)
01 -------------- 10A ------- Dim dip headlights
02 -------------- 20A ------- Central door locking, anti-theft alarm
03 -------------- 20A ------- Cooling fan
04 -------------- 30A ------- Sunroof
05 -------------- 10A ------- Lights
06 -------------- 30A ------- Headlight washers
07 -------------- 15A ------- Interior light
08 -------------- 15A ------- Cooling fan
09 -------------- 10A ------- Engine management system
10 -------------- 20A ------- Front seat height adjustment
11 -------------- 7.5A ------ ...
12 -------------- 7.5A ------ Radio/cassette player
13 -------------- 20A ------- Window - rear left
14 -------------- 20A ------- Window - rear right
15 -------------- 20A ------- Window - front left
16 -------------- 20A ------- Window - front right
17 -------------- 20A ------- Headlight - right
18 -------------- 20A ------- Stop lights, horn
19 -------------- 20A ------- Headlight - left
20 -------------- 10A ------- Dim dip headlights
21 -------------- 10A ------- Hazard warning lights
Post '96
04 -------------- 10A ------- Cruise control (618, 620i, Si, SLi & 623 models)
05 -------------- 7.5A ------ Headlight adjuster, mirrors and sunroof
09 -------------- 7.5A ------ Air conditioning (618, 620i, Si, SLi & 623 models)
10 -------------- 7.5A ------ ABS
11 -------------- 15A ------- Radio aerial, cigar lighter
12 -------------- 7.5A ------ Starting signal (618, 620i, Si, SLi & 623 models)
ENGINE COMPARTMENT FUSE BOX (English)
01 -------------- 10A ------- Tail lights
03 -------------- 20A ------- Cooling fan (618, 620i, Si, SLi, GSi & 623 models)
06 -------------- 30A ------- Cooling fan (620ti & Diesel models)
08 -------------- 15A ------- Cooling fan (618, 620i, Si, SLi, GSi & 623 models)
-.. -------------- 10A ------- Diagnostics (620ti & Diesel models)
10 -------------- 20A ------- Front seat height adjustment (618, 620i, Si, SLi, GSi & 623 models)
11 -------------- 10A ------- Front fog lights (618, 620i, Si, SLi, GSi & 623 models)
-.. -------------- 30A ------- Cooling fan (620ti & Diesel models)
12 -------------- 20A ------- Front seat (618, 620i, Si, SLi, GSi & 623 models)
-.. -------------- 15A ------- Front fog lights (620ti & Diesel models)
13 -------------- 7.5A ------ Radio/cassette player
14 -------------- 20A ------- Window - rear left
15 -------------- 20A ------- Window - rear right
16 -------------- 20A ------- Window - front left
17 -------------- 20A ------- Window - front right
18 -------------- 20A ------- Headlight - right
19 -------------- 20A ------- Stop lights, horn
20 -------------- 20A ------- Headlight - left
21 -------------- 10A ------- ...
22 -------------- 10A ------- Hazard warning lights, anti-theft alarm
11 -------------- 20A ------- Front seat (618, 620i, Si, SLi, GSi & 623 models)
20 -------------- 10A ------- ...
21 -------------- 10A ------- Hazard warning lights, anti-theft alarm
22 -------------- 15A ------- Front fog lights (618, 620i, Si, SLi, GSi & 623 models)
· Rover Lifestyle
Rover 200 Rover 600
Discussion Starter · #5 · (Edited)
Rover 600 Post '96 Engine Compartment Fusebox
1.8, 2.0 & 2.3 PGM-Fi vehicles only
Fuse -- Rating -- Wire Colour -- Function
__________________________________________________________________________________
15 ---- 80 amp -- - ------------ Main Fuse1
16 ---- 50 amp -- W ------------ Ignition Switch
17 ---- 40 amp -- B/G ---------- Heated Rear Window
18 ---- 30 amp -- W ------------ Blower Motor
19 ---- - ------- - ------------ not used
20 ---- 10 amp -- R/G ---------- Interior Illumination Lamps and Sidelamps
21 ---- 20 amp -- W/U ---------- Theft Alarm and Door Lock
22 ---- - ------- - ------------ not used
23 ---- - ------- - ------------ not used
24 ---- - ------- - ------------ not used
25 ---- 20 amp -- U/B ---------- Cooling Fan
26 ---- 30 amp -- G ------------ Sunroof
27 ---- 10 amp -- U/R ---------- Rear Fog Lamps
28 ---- - ------- - ------------ not used
29 ---- 15 amp -- W/U ---------- Interior Lamps/Electric Aerial/Diagnostic
--.............................. Socket/Integrated Control Unit
30 ---- 15 amp -- W ------------ Condenser Fan/Compressor Clutch/ Cooling Fan
--.............................. Timer Relay
31 ---- 10 amp -- Y/U ---------- Main Relay and Engine Immobilisation Control Unit
32 ---- 20 amp -- W/G ---------- Power Seat
33 ---- 15 amp -- W ------------ Front Fog Lamps
34 ---- 20 amp -- W/R ---------- Power Seat (recline)
35 ---- 7.5 amp - W/Y ---------- Backup voltage - Radio/Clock/Instrument
--.............................. Pack/Engine
--.............................. Management/Automatic Transmission
36 ---- 20 amp -- G/B ---------- LH rear Power Window
37 ---- 20 amp -- Y/B ---------- RH rear Power Window
38 ---- 20 amp -- U/B(RHD) or -- LH front Power Window
--............... W/Y(LHD)
39 ---- 20 amp -- W/Y(RHD) or -- RH front Power Window
--............... U/B(LHD)
40 ---- 20 amp -- R/G ---------- RH Headlamp and Main Beam Indicator
41 ---- 20 amp -- W/Y ---------- Horns/Brake Lamps and Set/Resume Switch
42 ---- 20 amp -- R/Y ---------- LH Headlamp
43 ---- - ------- - ------------ not used
44 ---- 10 amp -- W/G ---------- Direction Indicator and Hazard Lamps/Theft Alarm
An ABS fuse box is mounted close to the engine compartment fuse box. This
contains one fuse fixed in position with two cross-headed screws and one pull
out fuse.
ABS FUSE BOX ( 1.8, 2.0 & 2.3 PGM-Fi vehicles only )
45 ---- 40 amp -- W/U ---------- ABS modulator
46 ---- - ------- - ------------ Not used
47 ---- 20 amp -- W/G ---------- ABS modulator
2.0L Turbo and Diesel
15 ---- 80 amp -- - ------------ Main fuse
16 ---- 50 amp -- N/K ---------- Ignition A
17 ---- 40 amp -- B/G ---------- HRW
18 ---- 30 amp -- W ------------ Blower motor
19 ---- 30 amp -- N/LG ---------- Engine management
20 ---- 10 amp -- R/G ---------- Lighting switch
21 ---- 20 amp -- W/U ---------- Anti-theft alarm
22 ---- - ------- - ------------ Not used
23 ---- - ------- - ------------ Not used
24 ---- - ------- - ------------ Not used
25 ---- - ------- - ------------ Not used
27 ---- 10 amp -- U/R ---------- Lighting switch
28 ---- 30 amp -- N/G ---------- Cooling fans
29 ---- 15 amp -- W/U ---------- Interior light
30 ---- 15 amp -- P ------------ Diagnostics
31 ---- 10 amp -- Y/U ---------- Main relay/engine immobilisation
32 ---- 20 amp -- W/G ---------- Drivers’s seat
33 ---- 15 amp -- N/U ---------- Aircon relay module
34 ---- 20 amp -- W ------------ Front fog lamp
35 ---- 7.5 amp - W/Y ---------- Radio cassette
36 ---- 20 amp -- G/B ---------- Window - rear left
37 ---- 20 amp -- Y/B ---------- Window - rear right
38 ---- 20 amp -- U/B(LHD) or -- Window - front left
--............... W/Y(RHD)
39 ---- 20 amp -- W/Y(LHD) or -- Window - front right
--............... U/B(RHD)
40 ---- 20 amp -- R/G ---------- Headlight - right
41 ---- 20 amp -- W/Y ---------- Stop lights/horn
42 ---- 20 amp -- R/Y ---------- Headlight - left
43 ---- - ------- - ------------ Not used
44 ---- 10 amp -- W/G ---------- Hazard warning lights/alarm
A stand alone 60A fuse (ABS) and a stand alone 80A fuse (battery cable
protection) are mounted in the left hand side of the engine compartment.
· Rover Lifestyle
Rover 200 Rover 600
Discussion Starter · #6 · (Edited)
Rover 600 Post '96 Passanger Compartment Fusebox
01 ---- 7.5 amp - Y/W ---------- Theft Alarm
02 ---- 15 amp -- R/W and R ---- SRS and Inertia Switch
03 ---- 10 amp -- P ------------ SRS (Airbag)
04 ---- 10 amp -- B/Y ---------- Engine Management/Automatic
--.............................. Transmission/Engine Immobilisation/Alternator
--.............................. /Charge Warning Indicator/Cruise Control/Cooling
--.............................. Fan Timer Relay
05 ---- 7.5 amp - Y/G ---------- Power Windows/Mirrors/Sunroof/Headlamp Levelling
06 ---- 30 amp -- G/B ---------- Wipers and Washers/Integrated Control Unit---
07 ---- 7.5 amp - Y/B ---------- Cooling Fans/Air Conditioning/Heater/Heated Rear
--.............................. Window
08 ---- 10 amp -- Y ------------ Direction Indicator Lamps/Hazard Lamps/Reverse
--.............................. Lamps/Instrument Pack/Integrated Control
--.............................. Unit/Clock(LHD)
09 ---- 7.5 amp - B/Y ---------- Compressor Clutch Relay
10 ---- 10 amp -- Y/U ---------- Anti-lock Brakes (ABS)
11 ---- 15 amp -- Y/R ---------- Radio and Cigar Lighter
12 ---- 7.5 amp - B/W and U/R -- Start input - Engine Management
13 ---- - ------- - ------------ not used
01 ---- 7.5 amp - Y/W ---------- Anti-theft alarm
02 ---- 15 amp -- B/Y,R/W & Y -- Engine management
03 ---- 10 amp -- R ------------ Airbag control unit
04 ---- 10 amp -- B/Y ---------- Engine immobilisation control unit/cruise control/instrument packet
05 ---- 7.5 amp - Y/G ---------- Headlamp levelling
06 ---- 30 amp -- P ------------ Windscreen wipers and washers/integrated control unit
07 ---- 7.5 amp - Y/B ---------- HRW/blower fan
08 ---- 10 amp -- Y and B/Y ---- Instrument pack/hazard warning/reversing lights
09 ---- - ------- - ------------ Not used
10 ---- 10 amp -- G/K ---------- ABS modulator
11 ---- 15 amp -- Y/R ---------- Radio cassette player/cigar lighter
12 ---- - ------- - ------------ Not used
13 ---- - ------- - ------------ Not used
· Rover Lifestyle
Rover 200 Rover 600
Discussion Starter · #7 · (Edited)
Rover 600 Post '96 Satellite Fuse Block - 2.0L Turbo only
51 ---- 10 amp -- N/K ---------- ECM positive feed, stepper motor
52 ---- 20 amp -- N/K ---------- Ignition coil, boost pressure sensor, purge valve,
--.............................. aircon relay module
53 ---- 10 amp -- N/K ---------- Injectors
54 ---- 10 amp -- N/U ---------- Oxygen sensor
55 ---- 10 amp -- G/K ---------- MEMS relay module, ignition sense
1 - 9 of 9 Posts
