1 - 5 of 5 Posts
When I come to a halt and switch the ignition off, the engine stays running. To stop it I put it in 5th gear and stall it. I have tried fitting a new stop solenoid on the pump but when I start it up again and then swith it off it still won't stop. Does anyone have any suggestions please? Thanks.
when you changed the solinoid did you change the the plunger with the rubber seal on the end or did you leave the old one in. the rubber on the end gets split and fails to stop the fuel even if the solinoid works perfect.
after turning off the engine with the key check for power at the solinoid with a test light or multimeter, if theres no power then your solinoid is still at fault and not shutting of the fuel. if the power is still there you got an electrical fault along the line.
1 - 5 of 5 Posts
