1 - 12 of 12 Posts
Rover Lifestyle
Rover 200 Rover 600
Discussion Starter #2 (Edited)
Rover 400
ECU locations
1. Window lift ECU (in the drivers door)
2. Multi Function Unit (MFU) - below steering wheel
3. PGM-Fi ECU - 416 Automatic only
4. SRS ECU (behind centre console)
5. Anti-theft alarm ECU & central door locking ECU (behind centre concole)
6. MEMS 1.9 (except 416 Automatic) or BOSCH ECU (in case of some Diesel)
7. ABS ECU - 416 Automatic
8. ABS ECU - except 416 Automatic
Relay locations
- In engine compartment
01. Main relay module --- to VIN WD274935 - YWB100710
----------------------- from VIN WD274936 - YWB100970
02. A/C relay module - YWB100800/1
03. Main relay - YWB100560/790 (Diesel engine only)
04. Starter relay - YWB100560/790 (Diesel engine only)
NOTE:-- to VIN WD274935 - YWB100560
------from VIN WD274936 - YWB100790
- Behined centre console
05. Rear wiper relay - YWB10032 - RH side
06. Power wash relay - YWB10027 - RH side
07. Front Fog Lamp Relay - YWB10027 - RH side
08. Cruise Relay - SCB100140 - RH side
09. Daylight Running Lights Relay - YWB10032 - RH side
10. Starter relay - YWB100630 - (416 Automatic only) - LH side
- Behined RH side of facia
11. Main relay module - YWB100590 (416 Automatic only)
12. Passanger seat relay box - YWB10050
13. Drivers seat relay box - YWB10050
- Roof
14. Sunroof relay 1 - YWB10032
15. Sunroof relay 2 - YWB10032
Honda engine 1600 Automatic gearbox ABS fusebox
Engine compartment fusebox
- Relays
1. Cooling Fan Relay (non aircon) - YWB10027
2. Heater/Blower Motor Relay - YWB10027
3. HRW Relay - YWB10027
-Fuse--Rating---Function
--A----80 amp---Main fuse
--B----50 amp---Column switch, feeds fuses 19 and 20 in the passenger compartment fuse box
--C----50 amp---Ignition switch
--D----40 amp---Air conditioner
--E----30 amp---Blower motor
--F----50 amp---Window lift,feeds fuses 1, 3, 6 and 11 in the passenger compartment fuse box
--G----30 amp---Relay module (air conditioning)
--H----15 amp---MEMS relay and inertia switch
--J----7.5 amp--ICE/clock
--K----30 amp---Cooling fans/air con
--L----30 amp---Heated rear window
--M----20 amp---MFU/hand brake/horns
--N----10 amp---Hazard indicator
Passenger compartment fusebox
- Relays (R)
1. Window lift Relay - YWB10027
2. Flasher Relay - YWT10003
--1----30 amp---Sunroof (relays 1 & 2)
--2----20 amp---Heated seats
--3----7.5 amp--Taildoor/Interior lamp
--4----20 amp---RH rear window switch
--5----20 amp---Window control unit/driver’s window switch
--6----20 amp---Alarm ECU
--7----20 amp---LH rear window switch
--8----20 amp---Passenger window switch
--9----10 amp---RH headlamp
-10----10 amp---LH headlamp/main beam warning light
-11----15 amp---Front fog lamp relay
-12-------------not used
-13----7.5 amp--Fresh air circulation/mirror switch/air conditioning
-14----20 amp---Rear wiper motor/Sunroof relays
-15----10 amp---Dim dip (up to 97.5 MY)
----------------MFU/alarm/instruments/reverse lamps/hazard/amps/twin airbag
-16----10 amp---ABS modulator
-17----10 amp---Dim dip resistor (RHD only) up to 97.5 MY
-18----7.5 amp--Multi-function relay unit (starter relay for Rover ECM)
-19----10 amp---RH rear lamp/side, number plate light and illumination
-20----7.5 amp--Multi-function unit
-21----10 amp---RH headlamp (dipped)
-22----10 amp---LH headlamp (dipped)
-23----15 amp---Cigar lighter/radio/clock
-24----15 amp---MEMS/Instruments/speed sensor/relays
----------------Fuel pump (416 Honda Automatic)
-25-----3 amp---SRS (twin)
-26----15 amp---Engine
-27----15 amp---Ignition coil (416 Honda Automatic)
Rover Lifestyle
Rover 200 Rover 600
Discussion Starter #3 (Edited)
Rover 45 / MG ZS mk1
ECU locations
1. Window lift ECU (behind driver's door trim panel)
3. Cruise control ECU - SCB100190 (behind centre console RH side)
4. SRS ECU (in rear of centre console)
5. Anti-theft alarm ECU & central door locking ECU (behind front of centre console)
6. MEMS 3 engine ECU
7. ABS ECU (rear of engine compartment - bulkhead - on passenger's side)
8. Electronic automatic transmission (base of passenger's "A" post)
Relay locations
1. Starter relay (base of LH "A" post) - YWB100560/790
2. Glow plug relay (Front LH side of engine compartment) - L-series engine
----w/o intercooler (TCieM) - YWB100700
----w/ intercooler (TCie) --- YWB100560/790
- Behined centre console - RH side
3. Rear wiper relay - YWB10032
4. Horn relay - YWB10027
5. Reverse relay - YWB10027
- Roof
7. Sunroof relay 1 - YWB10032
8. Sunroof relay 2 - YWB10032
9. Cooling fan relay - behind LH side of front bumper - YWB101220
Relays (R)
1. Not fitted.
2. Heated Rear Window (HRW) relay.
3. Fuel pump relay.
4. Main relay.
5. Blower motor relay.
6. Front fog lamp relay.
7. A/C compressor clutch relay.
--Link--Rating--Vehicle--Function--
---FL1--150 A-----All----Alternator.
---FL2---80 A-----All----Window lift relay, fuse 1, fuse 2, fuse 3, fuse 6, and fuse 11 of the
-------------------------passenger compartment fuse box.
---FL3---50 A-----All----Ignition switch, fuse 27 of the passenger compartment satellite fuse box.
---FL4---80 A--L Series--Cooling fan relay.
--------------& K Series-
---FL4---80 A-----KV6----Cooling fan control unit.
---FL5-------------------Not fitted
---FL6--100 A--L Series--Glow plug relay.
---FL7---40 A-----All----HRW relay.
---FL8---50 A-----All----ABS ECU.
---FL9---50 A-----All----Lighting switch, fuse 20 of the passenger compartment fuse box.
--FL10---40 A-----All----Blower relay.
--FL11---50 A---A/C------Condenser fan.
--------------vehicles---
----------------only-----
--FL12---50 A-----All----Starter relay.
--Fuse--Rating--Vehicle--Function--
---F1----15 A--L Series--Alternator, speed transducer, ECM, Clutch pedal position switch.
---F1----15 A--K Series--Speed transducer, gearbox secondary speed sensor, HO2S.
---F1----15 A----KV6-----Butterfly valve, balance valve, CKP sensor, purge control valve, HO2S.
---F2----20 A--K Series--Gearbox Interface Unit (GIU), Automatic transmission selector.
---F2----20 A----KV6-----Automatic transmission selector, automatic transmission ECU, GIU.
---F3----15 A--L Series--Glow plug relay, MAF sensor, EGR solenoid, fuel pump.
---F3----15 A--K Series--HO2S, purge control valve, CMP sensor.
---F3----15 A----KV6-----HO2S, CMP sensor.
---F4----10 A--L Series--Compressor clutch relay, cooling fan relay.
---F4----10 A----KV6-----Compressor clutch relay, condenser fan control unit, cooling fan control
-------------------------unit.
---F5----10 A----All-----MFU, brake pedal switch, horn relay.
---F6----15 A----All-----Front fog lamp relay.
---F7----15 A----All-----Hazard warning switch, instrument pack.
---F8----15 A----All-----Radio/cassette player, radio/CD player, radio remote display, clock.
---F9----10 A----All-----Compressor clutch relay.
--F10----20 A----All-----Inertia switch, fuel pump relay.
Pasanger compartment fusebox
---F1----30 A-----All----Sunroof open relay, sunroof close relay.
---F2----20 A-----All----RH heated seat relay, LH heated seat relay.
---F3---7.5 A-----All----Luggage compartment interior lamp, passenger compartment interior lamp,
-------------------------diagnostic socket, folding door mirror ECU.
---F4----20 A-----All----Door mounted RH rear window switch, console mounted RH window switch.
---F5----20 A-----All----Window lift ECU, console mounted RH front window switch.
---F6----20 A-----All----Anti-theft alarm ECU, instrument pack.
---F7----20 A-----All----Door mounted LH rear window switch, console mounted RH window switch,
-------------------------sunroof open relay, sunroof close relay.
---F8----20 A-----All----Console mounted LH window switch.
---F9----10 A-----All----RH headlamp.
--F10----10 A-----All----LH headlamp, instrument pack.
--F11----20 A--K Series--ECM.
----------------& KV6----
--F12----15 A--L Series--ECM, alternator, instrument pack.
--F12----15 A----KV6-----ECM, alternator, instrument pack, cruise control relay, cruise control
-------------------------switch.
--F13----15 A-----All----Mirror switch, driver door mirror, passenger door mirror, A/C switch pack,
-------------------------fresh/recirculated air motor, fresh/re-circulated air switch, RH seat
-------------------------heater, LH seat heater, folding mirror ECU, rear wiper motor.
--F14--------------------Not used.
--F15----10 A-----All----Headlamp levelling switch, seat belt switch, MFU, reverse lamp switch, CVT
-------------------------switch, reverse lamp relay, anti-theft alarm ECU, instrument pack, hazard
-------------------------warning switch.
--F16----10 A-----All----ABS ECU.
--F17----10 A-----LHD----LH tail lamp.
--F18---7.5 A-----All----Starter relay.
--F19----10 A-----All----RH tail lamp, LH tail lamp (RHD only), RH rear number plate lamp, LH rear
-------------------------number plate lamp, RH headlamp, LH headlamp, MFU, sport/snow switch, fog
-------------------------lamp switch, glove box lamp, HRW switch, radio/cassette player, radio/CD
-------------------------player, cigar lighter illumination, heater control illumination.
--F20---7.5 A-----All----MFU.
--F21----10 A-----All----RH headlamp.
--F22----10 A-----All----LH headlamp.
--F23----15 A-----All----Radio/cassette player, cigar lighter, remote display/clock, radio/CD player,
-------------------------audio system interface unit.
Pasanger compartment sattelite fusebox (fuse holders)
--F25-----3 A-----All----SRS DCU.
--F26----20 A-----All----Power wash relay.
--F27----20 A-----All----Rear wiper relay, windscreen wash/wipe switch.
Rover Lifestyle
Rover 200 Rover 600
Discussion Starter #4 (Edited)
Rover 45 / MG ZS mk2
ECU locations
01. Cruise control ECU - SCB100190 (behind centre console RH side)
02. Anti-theft alarm ECU & central door locking ECU (behind front of centre console)
03. MEMS 3 engine ECU
04. SRS ECU (in rear of centre console)
05. ABS ECU (rear of engine compartment - bulkhead - on passenger's side)
06. Puls width ECU (passenger "A" post)
07. Air temperature Control (ATC) ECU (behind centre console)
08. Electronic automatic transmission (base of passenger's "A" post)
09. Park distance control (Behind carpet - luggage compartment - RH side)
10. Mirror Folding ECU (behind pasanger door trim panel)
Relay locations
01. Cruise control relay - base of passenger 'A' post - YWB10027
02. Cooling fan relay - behind LH side of front bumper - YWB101220
03. Blower recirculation relay - behined centre of front console - YWB10032
04. Air conditioning relay - behined centre of front console - YWB10027
05. Boot release relay - behined centre of front console - YWB10027
06. Reverse relay - beside passenger compartment fusebox RH side - YWB10027
07. Horn relay - beside passenger compartment fusebox RH side - YWB10027
08. Glow plug relay (Front LH side of engine compartment) - L-series engine
- Roof
09. Sunroof relay 1 - YWB10032
10. Sunroof relay 2 - YWB10032
Relays (R)
1. Not fitted.
3. Fuel pump relay.
4. Main relay.
---FL2---80 A-----All----Feeds fuse 1, fuse 3, fuse 5, fuse 7, and fuse 9 of the
---FL3---50 A-----All----Feeds fuse 18 of the passenger compartment fuse box.
---FL9---50 A-----All----Feeds fuse 17 of the passenger compartment fuse box.
--Fuse--Rating--Function--
---F1----20 A---SCU, BBUS, Alarm LED.
---F2----20 A---Window Lift Rear RH.
---F3----15 A---ECM
---F4----20 A---Window Lift Rear LH.
---F5----10 A---Interior Lamps, Boot Lamp, Diagnostic Socket.
---F6----20 A---Window Lift Passenger, Sunroof Relay Coils.
---F7----30 A---Sunroof.
---F8----20 A---Window lift driver.
---F9----20 A---Seat heat.
--F10----10 A---Headlamp main beam RH
--F11----10 A---Front Side-lights RH, Tail Lamp RH, No. Plate Lamp.
--F12----10 A---Headlamp Mainbeam LH.
--F13----10 A---Front Side-lights LH, Tail Lamp LH, Interior Illumination (Non Scand).
--F14----10 A---Headlamp dip RH.
--F15----10 A---DRL Interior illumination (Scand)
--F16----10 A---Headlamp dip LH
--F17----10 A---SCU, W/Lift Relay Coil
--F18----20 A---Power Wash.
--F19----15 A---Clock, Cigar Lighter, Radio.
--F20----10 A---Crank relay coil.
--F21----20 A---Wash/Wipe (Fr & Rr), Headlamp level motors.
--F22----Spare.
--F23----15 A---ECM, ACG, Cruise Relay & Switch, No-charge warning light.
--F24----10 A---ABS ECU.
--F25----10 A---SCU, Rev. Lamps, Auto Selector Lamp, Headlamp level Sw, IPK.
--F26----15 A---Rear Wiper Motor, Mirrors, Seat heat Relays, Blower Relay Coil, A/C Sw Pack, DRL
----------------(Scand), Recirc Motor, ATC.
--F27-----5 A---SRS DCU.
thank you roverlike for posting these diagrammes of fuses and the one i was searching for the starter relay
tucked behind the plastic foot guard on the passenger foot well below the a piller.i would never have found it with out your pictures..thank you
rover_45
Hi Roverlike.
I have been looking through the fuses diagrams that you so kindly uploaded to the forum, but I have an electrical problem that I just can't fix. So I thought that maybe you can help me??
The problem is this.
I have a rover 45 facelift 55 reg. 1.6 manual saloon. And on the windscreen wash wipe function the water sprays the screen but the wipers do not wipe. Every other function related to the wipers works fine. intermittent ect.
I have had all the relays replaced in the pektron box and checked fuses 18 and 21 which are both fine, I also removed the plastic covers from the steering column and removed 2 multiplugs from the wiper stalk and sprayed electrical contact cleaner on them and gave all the wires a wiggle, checking for loose connections, but all seemed fine.
But the fault is still there!!!!
Do you have any ideas what could be causing this??? or I might have to go to an auto electrician (lots of money)
Any help from you or indeed anyone that can help me will be greatly appreciated!!!
Kind Regards.
Bringe
Rover Lifestyle
Rover 200 Rover 600
Discussion Starter #8
Hi Bringe,
I read through your problem. Your windscreen wash is not followed by wipe.
Stalk switch provides signal to BCU unit, but after that all following relevant signals are provided by BCU unit. BCU unit provides signal to wash pump, and after that BCU unit should provide signal to wipe motor, which seems missing.
Problem is withoit BCU diagnostic, it is not possible to see why is this happening.
The best person for BCU units is Technozen. He provided very useful explanation of problems with BCU unit here: http://forums.mg-rover.org/how-do-i-answers-common-problems-8/pektron-scu-bcu-384938/
BCU unit is also called SCU unit.
My best suggestion would be to contact Technozen, either on this forum, or on his website: https://www.technozen-electronics.co.uk/
cityrover
Hello,
Why am I unable to see the pictures you have attached?
I registered hoping to fix issue with the started, but I need to identify the relay so I can check it first before going to repair/replace the starter itself.
Best regards,
Shamoni
Rover Lifestyle
Rover 200 Rover 600
Discussion Starter #10
I can see pictures in Chrome and Firefox browsers. Pictures are still hosted on Photobucket site, so it is either browser related or Photobucket related.
2004 Rover 45 2.0 TD impression
[/QUOTE
Hi. Is the starter relay easy to get to, without stripping out too many parts? Having changed the heater resistors to ceramics, the car now won't start. I'm thinking that I may have either blown a fuse or relay?! Has anyone had this happen?
-- 1995 -- Rover 400
-- 2000 -- Rover 45 / MG ZS mk1
-- 2004 -- Rover 45 / MG ZS mk2
Hi Every One, I have a Rover 45 se 1.6. 2004 with 73000 on the clock.
For the first time in my life I put my car into my local MG/Rover dealer here in Colchester as due to my cancer I have lost the dexterity in my fingers. I typed up exactly what I wanted doing i/e Repair/replace the cooling fan. Repair replace a multi plug relay only to be told that I would have to pay £114.00 for a diagnostic testiiii. I gave in and agreed.
2 days later I received a call and was told my car is ready for collection. I arrived at the garage and was told> that they had done a diagnostic test and that > [1] A full impact inspection had been carried out. [2] Unable to repair/replace the multi plug connector as a new harness is required which are not now available [3] The coolant is emulsified and suspect that the gasket is blown [4] Coolant fan now not available. [5] One tyre needs replacing the others on inspection proved to be fine except for some wear on one front tyre, cost to replace with Michelin £110.00. AAAHHHH and it goes on.
After I collected my car on arrival home I noticed my L/H rear door handle hanging off, it
was ok before I dropped my car off. When walking indoors as I looked back at the front of the car I noticed the bonnet didn't seem right, on investigation I found that the expansion tank pressure cap had not been replaced but left on the bulk head behind the tank next to the bonnet support hinge thus displacing the back of the bonnet. At the end of the report it said total cost of required repairs £1250.00 not counting cost of stripping but that parts required for my car are not easily available!!
Gosh what an experience. Why oh why did they carry did they carry out all those
tests rather than concentrate on my specific requests.
I have filled in their request for a "RATING" and attached a long long letter of concern and my amazement that they carried out a lot of tests that I didn't ask for not to mention that I didn't get a copy of the print out for the diagnostic test, ref thge blown gasket only 2 days earlier I did a compression test and all was well, the emulsification is down to the rad Weld that I put in some weeks ago. I let MG/Rover know my back ground i/e I have built 2 x Dutton kit cars, built a banger racing car, put a MAXI 1750 engine into my old mini van and rebuilt several engines so have experience of repairing cars.
I am pleased I have found this site of like minded petrol heads, indeed the information about the fuses and relays will be invaluable as the manual isn't all that clear. Haynes manuals are not as good as those 20 years ago.
hope to be in touch more often with this site. Thank you and keep safe
1 - 12 of 12 Posts
