1 - 20 of 20 Posts
I have a rover 25 1.4 2001. Changed water pump n belt couple weeks ago car was running fine. Today had to change thermostat because heater was cold and temp gauge started to go up. After fitting thermostat and bled system car is still boiling in header tank and heater still cold.any ideas?
Only got 47k miles. No symptoms of head gasket.oil is clean and no oil in header tank.its very strange
rover_streetwise
Could be the SAAB bypass valve plunger has failed and is now causing a blockage.
The Ranco/SAAB bypass valve was not fitted until 2004, so a 2001 car is unlikely to have one unless the pipework has been replaced with the newer type.
As you have had the system drained for the water pump replacement (which to be honest is a pointless change on an engine that has only done 47k - the factory fit Airtex pumps are very robust, and rarely need replacement that soon), I would think you have probably got an airlock.
The K series coolant system can be tricky to refill avoiding air locks, and even dealers used to have problems (which is why Rover specified the use of a vacuum fill system). First thing is to make sure the jiggle valve at the cam belt end of the inlet manifold is clean and free (it is what allows trapped gas out of the head back to the expansion tank). You will see it when you remove the bleed hose attached to that end of the inlet manifold. It is possible to fill the system effectively by removing the bleed screw from the coolant rail and also removing the small rubber pipe from the coolant elbow (where the temperature sensors are). Also ensure that the cabin heater is set to open/full heat (otherwise the heater matrix won't fill). Then pour the coolant into the expansion tank steadily until coolant comes out near the coolant elbow. At that point, re-attach the rubber hose and continue filling steadily (tightening the bleed screw when coolant without bubbles is flowing out. Once filled, start the engins and keep squeezing the radiator hoses as the engine warms to help disturb any trapped air bubbles that may be left. This is the method many of us use, and I have not had air lock problems by doing so.
Another possibility is a failed expansion tank cap - it is not uncommon, and results in the system failing to pressurise, which in turn allows the coolant to boil at normal operating temperature.
Discussion Starter #7
I only changed water pump cos it was leaking. Thank you for your help and advice i will try that and see what happens
Discussion Starter #9
I havnt had time to look at at due to work commitments but i will be doing it on monday. I also purchased a new radiator to go on aswell. Chances are the radiator is original which wont help it.
Yeah not a bad idea, if you need any bits or coolant use EuroCarParts and make the most of the discount code. (y)
Discussion Starter #11
Yea i will do cheers. What coolant do you recommend for it? I was just gonna use the usual red one
Yeah the Red/Orange OAT is the one I go for on mine, if you pop your reg in on Euro it 'usually' brings up the right one.
rover_25
Are my eyes playing tricks or is that 2 MLS gaskets i am seeing rather than one MLS and one shim?
Nigel
rover_25
check your liner heights before putting a new one in, the mls ISNOT an upgraded headgasket the payen750 blue is probally the best gasket as it can be used when the liners are not perfect
All 4 liners need to be 4thou proud of the block
Depends, more time consuming more than anything, the K-Series is easy to work on though, my valve seats were very pitted, gave them a good rub down, engine runs mint.
1 - 20 of 20 Posts
