The bottom of dads rover 25 (MKI) grill has come loose from the fastenings , how should it be fixed on there is some pins under the grill but these dont bite into the holes
there should be some little sprung clips/grippy things that go over the pins that you describe. If you look at them from the side they are shaped like a U, and have little spikie inside them which clasp onto these plastic pins which are attached to the bumper.
If somthing has hit your grill they have probably sprung off.
ah right , were can i get replacements from / wanyone know the part number for them ?
If you've a dealer nearby, from there is best. Probably pennies to buy, otherwise checker your local scrappers and anybody stripping a R25 on ebay.
Skelo
