Hello everyone,
I have a Rover 220SDi diesel ( 85hp) with a damaged engine and I have a very low milage rover 25 diesel engine I wish to fit to the car. As you know the 25 engine has a drive by wire electronic injector pump and an intercooler and higher pressure turbo and deeper recessed injectors I beleive.
Am I best changing over the injection system from the old engine but can I still use the intercooler assembly which I have including inlet manifold and can the old pump work ok with the new injectors or will I need to fit the old ones, any other help or suggestions would be much appreciated.
gonna be a hard swap from a non intercooled SD to an intercooled R25 engine, you're basically gonna need the entire wiring harness from the R25.
to do what you're wanting i have no idea
Hey
It's esay to put the intercooler on, I can talk you through it :).
You'll have to modify the throttle cable though, but it's easy enough.
hes wating to fit the 25 engine in, but retain the non IC fuel system as his engine is shot, not just fit the IC
