hello all,
my 1998 bubble shape rover 218 has recently developed a very slow coolant leak.
coolant is dripping from a weep hole between the clutch bell housing and the bottom of the cylinder block. can anyone tell me any likely causes for this? gaskets etc. is it a common fault, and how worried should i be?! there has been no oil/coolant mixing as far as i can tell. any pointers would be useful.
cheers
joe
Mmmm....Rover..
This sounds very like the inlet gasket manifold is leaking.
An updated gasket (green colour) and a combination of stud/nut fixings is the solution.
Any coolant leak on the K series engine should be addressed immediately, the low volume of coolant in the system doesn't leave any margin for leaks before overheating occurs.
The original bulletin is here...
http://homepage.ntlworld.ie/technozen/techbull/k_series_inlet_manifold_gasket.zip
hello,
thanks for the quick response.
how would the coolant get from the manifold to the bell housing area? i can't see any external leaks around the manifold gasket area.
cheers
joe
