1 - 1 of 1 Posts
Hi hope you can help me i've got a problem with my rev limiter and temperature gauge or thermostat. First is the temperature gauge the last 3 weeks has either been taking a while to rise to normal place or not moving much at all! Second is that i read on the forum that the engine should rev to about 7500rpm when the rev limiter kicks in. Now when i tried it it only went to 6800rpm then the rev limiter kicked in but then last week i was in second gear and it went to 7500rpm and the temp gauge was going to normal place. Now this week it is only going to 6800rpm again and the temp gauge is slow again could there be any conection between the to??? Not sure if the thermostat has a sensor that makes the rev limiter kick in early when its showing cold or if its a multituide of things thats wrong?? Please help P.S 1994 1.6 twin cam
1 - 1 of 1 Posts
