I have had this problem for some time now and have no more ideas as to what is causing it. The car starts and runs perfect and is in tip top condition, the problem starts shortly after starting. It will idle as it should for a bit then all of a sudden when the revs just start to drop off the idle becomes erratic and not as smooth as it should be. This lasts for a bit then goes ok, it happens whether the engine is hot or cold and if I drive off when it is doing it the car is hesitant to go.
I have recently given it a service and also changed the following:
Fuel Filter
HT Leads
Distributor Cap
Rotor Arm
Each of the above helped in the general running of the car but did'nt solve the problem. I am now out of ideas as I can't see anything wrong with the car and would appreciate it if anyone could throw a few ideas my way.
The car is a 1999 V-Reg 200 1.4
Thanks in advance
Fuel Filter
HT Leads
Distributor Cap
Rotor Arm
Thanks in advance
