constant flat batttery, constant jump starting, the last time i jumped my car i got it started took off the jump leads and it went dead with a click. when i hooked up the jump leads again and tryed to start it i noticed the glow plug light on the dash was not on and hasnt been since now my car wont start i've checked the timing belts, theyre ok so not mechanical, changed the large relay box as it was clicking but still not starting, changed ecu for another second hand ecu still nothing, but dont know if ecu was any good. as any1 got any ideas its doing my head in.
I have this problem :(
Was jump starting an Audi A4 cause battery was duff!
I hooked up negative lead to doner car chassis instead of A4 oops!
My 220 sdi wud not start but turns okay!
If starter turns engine battery is okay!
Checked fuses and glow plug fuse 50 amp in engine bay fuse box was blown!
Changed it but still doesnt start!
Changed glow plug relay but nothing aswell!
Does click but this glow plug control box in front of fuse box in engine!
However noticed glow plug light in dash doesnt come on and speedo plus rev counter reads 70 mph / 1500 rpm when ignition is turned to Turn I
Any suggestions?
oh glug plugs are okay checked with meter!
