1 - 5 of 5 Posts
just bought p reg rover 214s bubble it had been stood aprox 6 months it starts and drives fine when towed to start but soon as you turn off engine and try to start on the key it just clicks like dead battery sound, bought new battery and starter motor but still the same, please help if you can. many thanks phil (rovermgman)
Like whats been said, check the cabling and fuses. For some reason, power is getting to the ignition system (it will run once started), but not to the starter. It sounds like a short, or a bad connection somewhere
thanks alot
a big thankyou to troy.mclure and enak. I found some fuses that i did'nt know existed problem solved starting like a dream now. once again thanks guys
thanks alot
1 - 5 of 5 Posts
