1 - 2 of 2 Posts
My front passenger seat won't pull forward as far as my driver's will. Is this a design fault, or are my seat rails duff?
Thanks in advance.
Liam. :)
rover_45
Two common problems with these and with the Meastro and Montego also. The front seats have two holes at the front and rear for diffrent mounting hence why it only goes so far. Check by moving both seats all the way back and check the front mounting holes and then move them both forward and check the holes at the back. The other is the runner stops could have been put in backward which also results in a shorter travel just like putting washers under the front mounting's to raise the seat up.
1 - 2 of 2 Posts
