What's the best way of removing fuel from the fuel tank of my partially stripped 214 SEi?
Can't use the engine, as half of it has been sold/stripped!!
Where is the fuel pump? Is it mechanical and run by the engine, or electrical that can be run off a battery to syphon the tank?
Dad wants to emty the tank, to put the fuel into his petrol lawnmower!!:broon:
Skelo
mg_zs
just syphon it out with a bit of hose ipe mate,
keep sucking till it comes out and let the weight of itself push most of it out then just disconnect a fuel line and catch the rest. at least that way it wont gush out
Think i'll let my dad get a mouth full of petrol then!!!
Would be nice to see, if there was a better tasting way of doing things tho.
Skelo
I've tried syphoning from my car and couldn't do it - the tube wouldn't go down into the tank. All I got was fumes - not nice! lol.
On my 220 Wedge, I connected a positive feed to the inertia switch behind the centre console and the fuel pump started pumping. I undid the fuel pipe from the fuel rail?? and connected a longer peice of pipe. I then fed into my freelander and operated until air bubbles appeared and the flow of fuel stopped.
Got about another 10 / 12 litres as the pointer fell below the red section.
Cut the fuel line under the car (lowest point), and catch in a pot. It's a scrapper ain't it? Saves getting petrol in your mouth.
