Ok, so my cd player has eaten my favourite cd and won't let go, so I need to remove it and throw it in the bin!
How do you do it?
Do I need any special tools?
Ta
How do you do it?
Ta
hirecarouk said:if its like most normal stereos then a set of stereo removal pins is only ÂŁ2 from most places like halfrauds! cant go wrong with them!
yep, they will remove any Standard fit head unit as long as it has 4 holes in the face 2 on the left 2 on the right on the edges of the plastic!Abigail said:hi
will the halfords pins remove a philips radio from a 214 1998?
cheers
hi thanks for that.my radio needs a code but worse than this there doesn't appear to be any power to it at all.ie it doesn't light up or buzz or anything at all.i've checked the fuses which seem ok.any other ideas?recarouk said:yep, they will remove any Standard fit head unit as long as it has 4 holes in the face 2 on the left 2 on the right on the edges of the plastic!
stick them in there and pull the head unit and it should slide straight out!
]Abigail said:hi thanks for that.my radio needs a code but worse than this there doesn't appear to be any power to it at all.ie it doesn't light up or buzz or anything at all.i've checked the fuses which seem ok.any other ideas?
cheers
t
Got some of those remover pins, but can't really see any holes, will go and take another look once the rain stops!recarouk said:if its like most normal stereos then a set of stereo removal pins is only ÂŁ2 from most places like halfrauds! cant go wrong with them!
hirecarouk said:]
have you had the head unit out??? check the connecter blocks behind it for loose wires although i just bought a 25 with a dead head unit so i took it out and threw it away got a decent sony CD player from Car audio direct for ÂŁ49.99 Bargain!
the fuse was ok, it wouldnt switch on and the screen stayed blankAbigail said:hi
how did you know it was dead?
cheers
hirecarouk said:the fuse was ok, it wouldnt switch on and the screen stayed blank
i tried it in my 200 and still nothing so pronounced it dead and filed it under B and put my JVC cd player in, fired up straight away!
no you have to get a harness adaptor depending on which CD Player you have there not cheap though cost about ÂŁ35 think theres one in the for sale section for a sony stereo though?Abigail said:hi
tried it in another car!DOH! why didn't i think of that.
if i replace it with another model radio/cd will the steering wheel controls still work?
cheers
ive looked at the unit theres one on ebay and your right there are no holes.dwilly said:Got some of those remover pins, but can't really see any holes, will go and take another look once the rain stops!
