Got to say i'm impressed with my Rover 25 diesel turbo, What PSI are folk running on their Turbos and what effect has it had on reliability as I feel tempted to crank mine up a bit?
Get her dyno'd again.Ok, this is all getting me excited. I ran 20.6 psi at WGT to get 157 bhp. Now, I am running 19.5 psi and had my timing tweaked and eliminated the black smoke. I am wondering if I broke 160 bhp!
Interesting, the claims I heard were that it was shaft wobble that was a critical problem (hence attention to detail balancing). But still, what you say makes logical sense.You can't "toughen" up a turbo so to speak, well not in terms of making it rotate faster. You can add a 360deg bearing which helps but doesn't alter the performance of the turbo at all it just makes it last longer!
As Dakta says, the stage 1 has a larger compressor map and so is different from the one I posted above. This essentially means it'll shift more air for a given turbo speed. Since the turbo speed is controlled by the exhaust turbine it means that the stage 1 will flow more air than the standard unit but will have similar spool characteristics. It'll spool slightly later but not much.
The stage 2 has a different compressor and exhaust turbine. This essentially means that it'll spool later but the exhaust side will be less restrictive at higher rpm's and so the power won't tail off as badly as the original unit. It'll make more power but will spool later in the rev range.
You can make a turbo spin faster than it is designed to, but it's life will be short and it may suffer a catastrophic failure. Hybrid turbos don't (or shouldn't) spin any faster than OE units. It is a materials property problem that limits the turbine speed rather than anything else.
I don't get that, okay so you're changing the manner fuel is delivered in a way that makes it easier to yield the energy contained in the fuel, but by limiting the quantity of fuel injected you actually limit the energy contained within the cylinder.Im starting to think that the SDI injectors will outperform the wingy injectors with the hybrids. My last RR result showed almost 160 bhp is achievable with the SDI injectors with very little fuel added. Matt is thinking that he can get around 180 bhp if he actually addes fuel the car can burn it.
Where the Wingy injectors simply dump masses amounts of fuel in and results in poor atomization and compressed unburnt fuel, I suspect that SDI injectors can achieve the same type of results as Mad's 178. bhp by using less fuel. In doing so, requires less air.
Roberto and Petes' cars are the ones to watch. They both will have similar setups, hybrid, FMIC and Reidy Remap, but differ in terms of injectors.
Shouldn't detonate unless you've advanced the timing too much.Im not exactly sure the reason why unburnt fuel affects power output. I do very much recall that WGT told Luke to turn down the fueling (too much smoke) and this would increase performance. I probably is not a matter of displacement, but the high EGT and detonation?
I'l tell you something, it's a bloody shame you didn't do a run with your second (reidy) map with the stage one hybrid. Would have told us so much.well just to put it up again,
mk1 - 167bhp, 264ft/lb
but it was a lovely nice flat torque curve eg. 240@2k, 260@2.4k, 230@3.8k
this was not a reidy remap at this stage, so no advance timing, etc.
http://i41.photobucket.com/albums/e289/mrkstrlng/Scan10113.jpg
mk2 178bhp, 312 ft/lb
http://i41.photobucket.com/albums/e289/mrkstrlng/Scan10115.jpg
now if you look at the graph, i had problems with something effecting the engine around 2.6/2.8k, were it was peaking and dropping off, which i feel was the start of the hgf.
but back on topic, i do feel that a new set of sdi's would give very precise remapping with big mods. But if you want to break 190-200, ure foing to need wingy injectors. i do feel that itomisation is the key to it. As kris has said the vag boys get alot of joy from changing nozzles, and there is obviously someone out there that know wat its all about.
i have noticed on the dyno, that cars running too much fuelling, usually give low torque figures, power isnt really affected as much.
Ok, I came across this graph: http://www.bycosin.se/comb_chart.htm
The wingy injectors have larger nozzle openings and this in turn, produces larger fuel drop size and poor atomization?
From the graph, we see that larger fuel drops have much longer combustion, heating and ignition time.
What ends up happening is the larger fuel drops do not completely burn and creating soot.
Although efficiency is easly explained, I am still stuck on max power output.
On a side note: I do have my set of hybrid injectors that atomize the fuel very well and they have brand new first stages that have been test and calibrated. I know with this injectors, if you get the first stages right, it does not matter what happen in the second stage. So what I am thinking is that I can but these new 1st stages onto my sdi 2nd stages and have tested and calibrated set of sdi injectors. Would this work?
The other option is to just drop off the sdi injectors to my diesel mechanic, but he will charge me ÂŁ200 and I dont think I would really see any benefits.
