1 - 11 of 11 Posts
mgf
Hi, one little thing. My rear view mirror vibrates excessively at speed, or even, not at speed. It seems to wobble around a lot, as if it is loose.
Did a Forum search....nothing!
Has anyone else come across this issue?
Makes it tricky to fully focus on the rear.........yes, I have the side mirrors, but I prefer the older rear vision mirror.
Access to the mirror underside is a bit limited.
mgf
Discussion Starter #4
Rear Mirror
Hi again Pete, have had a 'go' at pulling mirror off, but only gingerly.
Did not seem to want to come off.......did not quite follow your directions.
Is it the same unit...see photo, my car is a MY2000
yep, they are all the same, they can be a bit tricky to get off, you need to push the unit up in the same plane as the screen.
I usaully just push mine down back into the slide when it works lose and vibrates, doesn't happen very often
Gaz
The rear view mirror isn't loose on the screen but keeps jumping about when driving. I just get it positioned right & then it drops down a millimetre or 3 so that I'm looking mostly at the bottom of the rear window.
Really annoying.
Any suggestions please.
Mine wobbled- I just used a bit of card/paper wedged in the 'gap'. TO BE HONEST- it didnt bother me but my car ends up being lent out to family members when thiers breaks-down and my middle boy commeneted on it!!
1 - 11 of 11 Posts
