1 - 5 of 5 Posts
Hi guys, after some **** decided to bash my car last night and drive off. I've managed to do most repairs myself for nothing.
However - my rear driver-side door needs to be replaced. The scratches are pretty bad and i've been quoted a few hundred quid to get it sprayed.
I've submitted a request for a new door but was wondering how much it will cost to fit, the ease of it and where to go... any ideas.
Can you not physically fit the door yourself?
It isn't much of a problem to do that part, the spraying is the expensive bit.
Skelo
Never done it myself. So wouldn't know how to...
Plus i'm looking at the breakers yard for the same colour to save extreme cost
It's only a couple of bolts. All you need is someone to hold the door steady while you bolt it in. If you remove a door from the breakers then just pay attention to how you remove the door and reverse the process for fitting.
1 - 5 of 5 Posts
