1 - 1 of 1 Posts
· Registered
I have a 2005 model MGTF 160. The passenger external door handle has disconnected from the vertical rod and will not open door. The internal door handle mechanism is fine. I have taken off the trim and can just see the rod which I can pull up. I do not understand how to reconnect with the external door handle. In particular how do you get to the 2 bolts holding the door handle to remove the external handle if in fact hat is necessary. NY HELP IS APPRECIATED.
pAUL
1 - 1 of 1 Posts
