Can please someone help me with radio code for rover 75. rg745wy1062478
Some possibilities on the web for a few quids.
Useful links:
https://the75andztclub.co.uk/forum/showthread.php?t=79121
https://www.radiocodes.co.uk
https://www.the75andztclub.co.uk/forum/showpost.php?p=1672271&postcount=17
Then
How To Disable The Radio Code
If you want to de-activate the security code on the radio, the following steps will stop the need for you to input the code after a battery disconnect, however, this isn't a way of getting round unlocking it if you've lost the code, as you need to know what the code is in the first place, in order to disable it for the future. For the Alpine Symphony Radio: The security function is deactivated by holding the radio tuning search up button depressed while switching on the unit using the push on/off rotary volume control. Security code input will be requested on the LCD and audio output will be muted. Once the security code is successfully input, the audio output will be restored, 'CODE OFF' will appear briefly on the LCD, the unit will emit two 'beeps' and the security code function will be disabled. The security code can be reactivated by holding the radio tuning search up button depressed while switching on the unit using the push on/off rotary volume control. A 'CODE ON' message will be displayed on the LCD for approximately two seconds after two warning 'beeps'.
their are a number of sites you can join and they will give you the code for nothing , but dont expect to get it straight away after joining some times have to make a few posts , unless you know someone who is already a member on the sites and can get it for you faster .
I hope to find someone who can help me.
I've already done it once a few weeks ago on another forum for a non member because I'd no need for myself.
But unfortunately I'm not allowed to do it twice for another non member.
Good luck anyway.
