1 - 11 of 11 Posts
Do you need help entering your radio code?
We have the largest database in the UK of radio code entry instructions.
Please note: to help you we will require.
1, The make of CD or Cassette Player (example - Philips)
2, The model number (example - 22DC594 or 7 648 262 048
We will get back to you asap, if you need urgent help telephone
us on 01379 669 375 - 9am - 11pm.
Discussion Starter · #2 · (Edited)
CD 413x RADIO CODE ENTRY INSTRUCTIONS - WWW.MGROVERCODES.COM
MG Rover CD 413X (XQE000990PMA) VDO.
Please note that code entry is only possible with the ignition switched on, and when CODE is shown in the display.
If the display continually shows
WAIT then the unit may be code locked and will need to be left switched on
for up to two hours to reset before another code entry attempt is possible.
Switch The Radio On CODE will be shown on the display.
Press the preset 1 to start.
Press the tuning up button > for the first digit of the code.
Then press the preset 1
Press the tuning up button > for the second digit of the code.
Press the tuning up button > for the third digit of the code.
Press the tuning up button > for the fourth digit of the code.
Then check the display to make sure the code is correct then
finally press the preset
1 to activate the unit.
Discussion Starter · #3 · (Edited)
M3-100 ix-m03 xqe000710mbj radio code instructions - www.mgrovercodes.com
M3-100IX-M03 XQE000710MBJ
If the unit is codelocked, it must be left switched on for up to two hours before a further attempt at code entry.
Switch Unit On - Display Shows CODE then O O O O
Press preset
1 repeatedly for the 1st digit of the code
Press preset
2 repeatedly for the 2nd digit of the code
Press preset
3 repeatedly for the 3rd digit of the code
Press preset
4 repeatedly for the fourth digit of the code
Then press the right hand tuning knob to activate the unit.
The display will then show
APPROVED
Discussion Starter · #4 · (Edited)
MG Rover CD-80 XQE000570PMA IX-C03 RADIO CODE ENTRY INSTRUCTIONS
Please note that code entry is only possible when CODE 0000 is shown in the display.
If the unit is codelocked it will need to be left switched on up for up to two hours
Switch the unit on- Display Shows CODE 0000
Press preset
Press preset
Press preset
Press preset
4 repeatedly for the 4th digit of the code
If the correct code number is now shown
Press the right hand tuning knob to activate the unit.
Discussion Starter · #5 · (Edited)
MG Rover CR-80 IX-T03 Radio Code Entry Instructions.
If the unit is codelocked it will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Press preset
Press preset
Press preset
Press preset
APPROVED.
Discussion Starter · #6 · (Edited)
MG XQE 100 370 7 649 263 046 Radio Code Entry Instructions
MG XQE 100 370 - 7 649 263 046
Please note that code entry is only possible when the display
shows CODE - - - -. If the unit is codelocked, leave it switched on for
up to two hours and a further attempt at code entry should be possible.
Switch Unit On - Display Shows CODE then - - - -
Press preset
Press preset
Press preset
Press preset
Discussion Starter · #7 · (Edited)
MG XQE 100 380 Blaupunkt 7 640 263 346 Radio Code Instructions.
CODE then - - - -
Press preset
Press preset
Press preset
Press preset
Discussion Starter · #8 · (Edited)
Rover CC32 XQD 000390PUY Blaupunkt 7 642 161 310
Please note that code entry is only possible when CODE is shown in the display. If the display continually
shows WAIT 1 HOURthen the unit may be codelocked and will need to be left switched on
up for up toone hour to reset before another code entry attempt is possible.
Press preset
Press preset
Press preset
Press preset
Then press the tuning up button to activate the unit.
Discussion Starter · #9 · (Edited)
Rover R960 22DC710 / 60B Radio Code Entry Instructions.
Please note that code entry is only possible when 0 - - - is shown in the seperate display.
If the display continually shows CODE then the unit may be codelocked and will need to be left switched on
Switch Radio On - Display shows ROVER and then CODE
Press Preset " 1 " and the display shows 0 - - -
Press the tuning up button > for the 1st digit of the code.
Press the tuning up button > for the 2nd digit of the code.
Press the tuning up button > for the 3rd digit of the code.
Press the tuning up button > for the 4th digit of the code.
Then press the preset 1 to activate the unit.
Discussion Starter · #10 · (Edited)
Rover R860 22DC594 / 60L Radio Code Entry Instructions.
shows CODE. If the unit is codelocked, leave it switched on for up
ROVER and then CODE
1 - 11 of 11 Posts
