what a day its been!
Ok we have checked the following:
*Inspected the fuses, all look visually perfect.
*Removed the fan and tested it by connecting it to a battery jumper kit, the fan started up fine.
*Changed the brown coolant fan thermostatic switch for a brand new one.
Still the fan fails to kick in. Is the only other possibility the ECU?
Incidently, I read somewhere that unplugging the brown thermostatic switch, while the ignition is switched on should start the fan automatically. Is this correct? And does the fact that mine doesnt automatically start another bad sign pointing towards ECU probs?
