1 - 17 of 17 Posts
rover_75
How long should the Shocks on a R75 last?
How would I tell if mine have gone or not?
Its just that my car is smooth as always but if I go over a bump with the passenger side front wheel it seems to send a shock wave through the car (windows rattle etc) but I can go over the same bump but with drivers side and the car just eats the bump!
My Tank has done round 94k now!
push down on the corner of the car you suspect is not working.
it should go someting like.
move down from your push and then rise up and settle at the original ride height. if you get any bouncing then the shocks are worn.
Just worth a check is that the spring is still intact and not broken on either side. If the spring break is near the top or bottom the ride height will hardly change at all but the spring rate will, making the suspension uneven. Worth a look as it'll only take you 30 secs.
Check all the ball joints, have had this 'crashing noise' on other cars an often a failed ball joint can be the cause, notmally because the rubber boot on the joint has failed allowing water in, and premature ball joint failure.
I shall avoid any obvious jokes about seized ball joints!!
CAM
1 - 17 of 17 Posts
