1 - 8 of 8 Posts
I know where i can get a free bubble with HGF and a batterd 620ti with 92k on it thats been attacked by some scum. I think ive got somewhere to store these cars but i will have to check. The idea is to drop the t16 into the bubble as a non road going fun car for the track that will be shared tween me and a friend. My friend has far better knowlage than me and has no problem making a transplant.
How simple is the drop? seeing as i have potentialy got the two cars for parts, what else will i need? Can i pinch the brakes off the 620? Any problems that will most likely occour?
Only testing the water until i can confirm time, money and a place to do this.
- Posted this in 25 forum to no avail. hopefully ill get a good response from the heads around here.
you will need alsorts of wiring hacks as the 620 isnt the best donor for it.
brakes will also fit with some tweaking.
Just to say - I don't need any luxuries. Just lights, steering etc...
Cant you run these of very few wires? sorry, im completely dumbfound to electrics.
I think emps meant the 600s engine wiring loom. You may be able to use one from a old 200 turbo. Someone will correct me on that though.
Its been done quite a few times so the info is out there. If you can't find any on here then try rovertech.net as the conversion is not exactly a new one.
The only hard bits will be wiring (requires thinking about), the engine mount and the exhaust. Most other things are relatively straightforward.
Discussion Starter #8
matey in the topic says something about getting a r8 one?? why is that, whats wrong with the 620 as a donor?
1 - 8 of 8 Posts
