1 - 1 of 1 Posts
Hello all, changed the head unit in a '02 rover 25 (originally a blaupunkt unit) at the weekend but much to my alarm the speedo did not work afterwards.
After a small amount of investigation, it turns out that the speed pulse for the GALA volume control on the blaupunkt runs to the pin on the iso connector that would usually be the remote turn on wire - hence, as soon as you turn on the stereo, the remote masks the speed pulse and the speedo does not work.
Easy solution to this problem though - just remove this wire from the plug and put some insulation tape on it and then all is fine.
Just thought i would mentioin this just incase anyone else had had this problem
Bye
Dave
1 - 1 of 1 Posts
