I have just obtained an AP brake kit off ebay - brand new hub assembly :)
The only "fault" with these is that the n/s disc does not have the retaining screws fitted - are these the screws I need?
Although I am not sure they are the correct type as it appears there is a thread on the hub already - I hope they are not snapped in the hub :(
Stampy, I take it they are the screws on the B&G website.
If so, they are the correct ones.
if there is any screw left in the hub, you can remove the disc and use a pair of mole grips to unscrew it.
The other thing is, those screws are really only there to aid disc fitting.
The disc will be held securely in place with the roadwheel whilst driving.
as stated above, the screws are not really needed. They just stop the disc floating around when the wheel is off. They are not essential...
