Hi
Hope you can help
I have purchased a big brake upgrade kit from Power Train Projects
http://www.ptp-ltd.co.uk/shop/ProductDetails.aspx?productID=652
Here is the write up
The MGZR 105 brakes are good, but could be better and the reason why we have created our latest kit, the ‘Big brake up-grade’. EBC Turbo groove vented brake discs and larger brake calipers combine to replace the standard solid discs and calipers. EBC ‘Green Stuff’ brake pads are used as a better compound for Fast road and Track use. The complete package is quite simple to fit and once installed offers ultimate stopping performance with stunning looks.
The problem is..........
The garage are having a nightmare bleeding the brakes and can't get it to happen.
They tell me that there is too much pressure from the bigger calipers and that the break peddle is going to the floor and that (not sure of the correct term of part) something has blown due to the excess pressure and will cost approx £60 to replace, think it might be a cylinder!
I have spoken to sales dept at Power Train who assure me there is nothing wrong with the kit and that being a genuine Rover part there can be nothing wrong with it. I thought it was EBC (green stuff) myself!!
An engineer from Power Train is going to speak to the garage this afternoon to see if they can rectify the problem over the phone.
Otherwise all my original discs etc will be refitted.
There was nothing wrong with the existing set up so not sure what the problem is.
Or who or what is at fault
Any suggestions appreciated
Has anyone else fitted this upgrade??
Hope you can help
