hi again my gsi 2.0 16v 1993 has water coming out of the exhaust with some steam i found the water bottle bubbling up but found the problem a blocked water pipe on the water bottle but that may have caused hgf what do you think
rover_45
I think you worry to much about your 420. The T series is not known for head gasket issuses. But thats not to say it does not go. Steam out of the exhaust is common on any car. But the T series motor does produce a fair bit and it also smells reallly bad from start up when cold.
Refill the coolant and get any air out of it then run the engine and remove the cap. Observe to expansion tank. If bubbles of air appear then lets just say that isn't a good sign.
