1 - 5 of 5 Posts
just noticed that the power steering fluid level is just under the minium mark. i was gonna top up but thought i would drain and replace all the fluid since i don't know when it was last done. wondering what fluid should i use? and much will i need? also how do i go about draining the system? i know where its leaking from, seems to be the top hose with the small jubille clip. gonna remove it clean it all up and put a new clip on to be on the safe side.
many thanks in advance
Discussion Starter · #2 ·
could anyone give me some advice, theres nothing in the haynes manual about a complete power steering fluid change.
I don't think the power steering fluid needs routinely changing, which is probably why the Haynes doesn't mention it.
I had a leak from the bottom of the reservoir on our old 214 bubble. I thought there might be a crack in the pipe stub but it turned out it only needed a new jubilee clip, as you said.
1 - 5 of 5 Posts
