Does anyone know where I can the ECU checked for faults on reliable Rover diagnostic equipment in the Yorkshire area?
Cheers!
Cheers!
Any chance of letting us know what you think the potential faults are?
Someone here may know the answer!
Ron
For info car is automatic diesel 2.0 CDT SE
Faults are intermitent non-starting. The engine cranks but does not start, and LCD on the dash shows 'EP' which I understand refers to Emergency Programme. However, once the engine eventually starts the 'E' element of the message clears and shows the normal 'P' for park.
Will run and drive as normal (no gearbox problem) but once ignition is turned off sometimes will not start again and displays above message.
Clare
