1 - 20 of 29 Posts
mg_zt
Plenums we hear so much about them and the reason why is very clear below in the photo's that follow.
And even more important this time of year with the Autum leaf fall etc.
Last Year a member of the club Mike came to have his handbrake mod fitted, as i always do i checked the plenum's after asking if he had checked them it turned out he had only brought the car Sunday so the car was very new to him, he had looked at the plenums from the drivers side and could see some water and he also heard the sloshing sound when driving.
The results can be seen below so come on gents lets keep on top of these plenums do the spyhole mod and its only takes 2 minutes to check for water once applied.
Pic 1 water at least 3" deep
1
Pic 2 The water must have been deeper at some stage according the the pollen filter marks
Pic 3 starting to rod the plenum tube to clear the soggy leaves and dirt which as bunged up the lower tube
3
Pics 4 the water starts to flush out of the plenum this went on for at least 2 mins
4
Pic 5 Still pouring out strong
5
Pic 6 slowly stopping with the rain we have been having this so easly could have been worse ECU damage which would have been a crying shame as this MGZT as only 20000 mile on the clock.
6
Pic 7 All the water drained away this should not happen again as the spyhole mod was put in place and Mike shown how to rod them each week at the same time as checking his oil water etc.
7
So lets get checking the plenums right away there is no excuse not to even more so in these winter monthswhen its rained and then it can freeze creating a iced plug in the plenum tube then if it rains again with the iced plug in place it will soon fill up all the best Skicon.
This is how you can check your plenums if you have never checked them before this is mainly for new members that is why i have put this thread together so it is all in one place on how to check and also add the spyhole mod & leaf stopper/collector if you so wish in my opinion worth doing.
This is the windscreen scuttle panel/outer grille which will have to be removed to start checking the plenum for water ingress below Fig1
1
First peel off the weatherstrip up to the wiper fixing point at least Fig2
Now you can press in the plastic spring clips to remove the grille panel Fig 3
3
This will then allow you to remove it and store it safe for the time being Fig 4
4
Next step is to remove the front screw/clip sometimes you may have to prise this up if it will not screw out.Fig 5/6
5
Now removed put this safe also
6
Next prise up and remove the rear scuttle clips hold your finger over the top because these can fly off sometimes never to be found again Fig7/8
7
8
Remove the first three of these and again put them safe for re-fitting after Fig 9/10
9
10
This will now allow you to lift the front of the scuttle and get access to the shield panel tray which needs to be removed. Fig 11
11
You can grip and remove the shield panel tray and slid it carefully out from its recess Fig 12/13
12
13
This now exposes the lower plenum and pollen filter area this is also where the ECU resides and can get damaged if water is allowed to build up because of the blocked plenum tube Fig 14
14
Here you can see how i have rodded the tube with my choice of rodding tools a plumbers spring pipe bender 10mm or 15mm also note even though i check these every week that because of the deluge of rain we have had last year and this year water is still getting to a certain height from the line seen on the pollen filter, this was empty when i took these photo's but must be filling even though clear because of the shear volume of water Fig 15
15
This shows the rodding tool i use pipe bender with a boot lace and plastic tube the reason why will be seen later in the thread. Fig 16
16
The shield panel tray can now be re-fitted back into place Fig 17/18
17
18
This photo shows the spyhole mod so the plenum cab be checked and rodded in the future with out having to remove the scuttle clips and trays. Fig 19
19
Here you can see the rodding tool again in use showing why the lace and plastic tube is needed because the plenum is at least 24" deep Fig 20/21
20
21
Here you can how the spring as come all the way through the plenum and the tube until it reaches the ground under the car Fig 22
22
Once rodded and if you have the spyhole mod in place fit a rubber 25mm bung which can be easily removed rodding in the future Fig 23
23
Replace the front screw clip Fig 24
24
Replace the three scuttle back clips Fig 25/26
25
26
Next replace the rubber weatherstrip Fig 27
27
And last of all with the job finished refit the windscreen grille panel Fig 28/29
28
29
The plumber spring i use with lace and plastci tube attached for the extra length needed to get to the bottom of the plenum 10mm or 15mm obtained from Toolstation, Screwfix, B&Q etc Fig 30
30
Spyhole Mod helping rod the plenums
Pic 1a water at least 3" deep
1a
Below is how to do the spyhole mod you will need a rule pencil 25mm drill bit and a 25mm rubber bung Fig 1
1
With the scuttle shield panel removed measure 97mm and 180mm from the points in the photo below Fig 2/3
The line is 25mm /1" from the rib on the panel
3
Here you can see my template which i use at meets so i can easly turn over a good volume of trays in a few minutes Fig 4
4
With the panel marked out and your drill ready with its 25mm bit we/you can now drill the spyhole Fig 5
5
When you drill the scuttle tray makes sure you have support under the tray at all times Fig 6
6
7
8
9
10
Once drilled trim the hole to make it neat for the rubber bung to fit nice Fig 11
11
Spyhole mod done and ready for use Fig 12/
12
This shows the plumbers spring pipe bender Fig 13/14
13
14
If you intend to use the plumbers spring look for a 10mm or 15mm a boot lace and a tube mine was from an old wendy house but any 15mm tube will do 12" to 15" long Fig 15
15
Also grind or file the end of the spring to remove the curl so it is smooth and will easly go into the tube Fig 16
16
Spring being used in situ Fig 17/18
17
18
Hope this helps the new members and remember check the plenums regular Skicon.
checked ours yesterday and there was mud and water in there and its not long since we checked - so just shows its needs to be done regular
May I compliment you for a FANTASTIC write up! Well written and very clear. I hope everybody who hasn't done this now will do, no excuses!
I agree with the above complimentary comments- Great to see that 'org is still alive and kicking with brilliant How to's like this
Make it a STICKY please
R75 Diesel.
This info should replace item 45 in the existing sticky.
Much much more comprehensive.
A picture is worth a thousand words.
Colvert.
mg_zt
Discussion Starter · #12 ·
check regular
With the bad weather coming back with a vengence rain then snow and cold frosts check those plenums as water can freeze and cause a plug in the lower plenum and if it rains right after a cold spell they can fill up quickly ad we all know the outcome better to be safe than sorry :D Skicon
Well done bud, great write-up.
I've been a real advocator of checking the plenums regularly ever since joining this forum, but you'd be amazed how many times I've had people say "Mine won't need it, I don't park under trees etc." Their loss!
There is another way forward:
To position a plastic filter between the main plenum and n/s plenum. This prevents debris from entering the chamber shown in OP, which prevents the drain hole getting clogged. The filter is described on t'other side, although I don't know if the filter is still made/sold?
mg_zt
Discussion Starter · #15 ·
Yes still avalible but it does not stop the dry dust which blows down into the lower plenum and if the flap have not been trimmed this builds up then if it rains lightly mixes and creates mud bit of dry good weather again and you have your self a dirt plug pours down and the plenum fill up, lear debris collectors can be made from gutter netting £1
Formerly MGTurbo#261
Great write up and with excellent pics, really useful info for all 75 owners. Thanks for taking the time to do this.
mg_zt_t
Plenums
Great write up and step by step pics are exactly what I need as a first time MG and ZTT owner, who has very rarely been under the bonnet apart from for fluid checks previously. Cheers.
Fantastic!
Did this today after following this guide. Passenger side is bone dry and dirt free!
Drivers side however is full of dry leaves and my hands are too big to clear them out. Me thinks ill have to break up the leaves with a stick or something similar then Hoover the debri out.
1 - 20 of 29 Posts
