1 - 5 of 5 Posts
Hi,
just having another play with my Rover 45 and have a strange problem, has anyone else experienced this?
starts first time no hesitation engine sounds sweet, runs ok up to 2500 rpm but sluggish have checked all the hoses and turbo has been renewed, new fuel filter, then starts mis-firing lots of smoke slows down then picks up and then slows engine doesn’t stall.
new fuel in tank and the tank has been off for repairs so just wondering if something in the tank is restricting the fuel flow or if it’s the injection pump. Have swapped the injectors for a spare set and exactly the same problem.
rest of car is very good too good to give up now!
hope some L series experts are still around to help.
rover_sd1
Used a scope [ a cheap one that fits my mobile] look around the top and sides of the hydraulic head for leaks. I found mine leaking at the top of the hydraulic head. I am waiting for the O rings from the UK . Pretty sure thats my problem but I would check to see if the engines revs okay from start as there may be a problem with the TPS wiring.
Thanks for your reply and hope you manage to fix yours soon
just stripped the timing solenoid off and the filter attached looks rusty and compressed and there are holes in the gauze so suspect that’s not great news!
Rang my local diesel place but they cannot get the timing solenoids anymore. There is a seals kit on eBay but cannot see the gauze filter so will keep looking probably for another pump or timing solenoid if one turns up. No rush but would like to sort it, the rest of the car is in excellent condition.
Glad to hear that someone else Is still running these, cannot be many now still left.
Just managed to find a filter that fits on the end of the timing solenoid on eBay, mine has holes in!
No luck with the timing solenoids.
rover_sd1
Try here in future for the filter and parts 0 470 004 003, Fuel distributor injection pump BOSCH VP44, VP29/30, 0470004003 (dieselcatalog.online) they have an online seals and kit purchase. My bosch kit bought on ebay for 30.00 arrived with all filters anf gaskets.
If relacing all seals you will likely have a bother with the pump reasembly too as the hydraulic head bits fall appart. The link will help show you the parts and where they are placed. I suggest you hold the pump in a vice at a forty five degree angle when assembling. Do not be afraid to use a low temp grease to hold the hydraulic head bits together. Please feel free to pm me if you have an assembly problem. I got a lot of experience with all the quirks I had to overcome with mine.
1 - 5 of 5 Posts
