cityrover
I've had to remove the air intake panel (just below the windscreen) in order to remove the broken wiper motor. I've got the wiper motor sorted now but the retaining white plastic clips for the intake panel have gone brittle over the last 24 years and I need to replace them. There are 4 of these clips; does anyone know what they're called and where I can get them? See attached photo; I've marked one of the clips and one of the holes where there should be a clip. Any help / advice would be appreciated.
Hi I think the part number Julian has given is for glass support clip, If you have the original clips and they are in one piece try putting a very small yellow wall plug in the centre of them, or fill the centre with Araldite let it set then drill a small hole in the centre. Hope everything works out for you. Regards. D4KGP.
cityrover
I believe you need Nut - Lokut - Rectangular - DYH000210 X4
And possibly the x 2 Nut – Lokut – square – EYH10017
Yep - I've checked the Rimmer Bros website and you're right, the DYH000210 "clips" look right. Well done, I don't think I'd have found them by myself. I've ordered four which I should get sometime next week. Thanks.... Alan
