I have gathered that electric windows on these 600's are a nightmare :(
my passenger window dont work because the little white plastic thing that runs along the runner thing has snapped :( therefore window tilts all over the place if moved down.
Is there anyway to replace/fix this issue without spending a fortune, or having to replace entire mechanism???
Many thanks in advance
has it t fallen off the glass the plastic bit?
It will be very cheap to fix, find a good one in a local scrapyard. You may need a new window and not the motor as the runners are glued to the glass and do come off! Check to see what has disconnected and get a scrapyard replacement,
Plastic bit broke on mine too. I bought a brand new mechanism from eBay for around £40 posted (you don't need to buy a new motor, that can be swapped over from the old mechanism), and fitted it myself with a Haynes manual for reference. Was a fiddly job getting it positioned right, but not too difficult. The key is to grease the rubber guide channels well when reassembling.
