Dear Friends,can i order a key without the electroic part.?Actually,only the casing is broken[a hole],i noticed the keyblade is stick to the casing,so can i just buy the keyblade & the casing[most likely is cheaper].?Thanks..
Yes,the transponder & the transmitter can be easily remove,only the keyblade.......very stubborn.....need a bench vice to clamp it..The keyblade is only a push fit into the casing so you should be able to transfer that over. The question then I guess is whether you can open the casing to transfer the transponder and transmitter to another casing. That I haven't tried.
