I needed to do an oil change (owned the car for a year now) and had heard stories that refilling via the port next to the dipstick was EXTREEMLY slow, so I was prepared to go through all the hassle of removing engine cover BUT:
When I checked the owner's handbook for oil grade and volume I needed, it stated: "If necessary, remove the filler cap and add oil WITH THE DIPSTICK REMOVED!" (The capitals and exclamation mark are exactly as-in the handbook.)
So, I decided to try filling via the port in photo below, and checked the time before I started. Result: 14 minutes to put 4.5 litres in. I am certain that I could have finished more quickly. I assumed that it would be very slow, so I initially did other jobs while I waited for oil to drain into the sump. The first two times I returned, no oil was in-sight, so I then poured slowly and kept watch on the dipstick tube. Only once did oil threaten to overflow up this pipe, which is conveniently slightly lower than the mouth of the adjacent spout. A gloved finger stopped the threat of overflow easily.
I decided to send this message to encourage anyone who, like me:
a. Only needs to do an oil & filter change, so no overriding need to remove engine cover to access plugs, air filter etc.
b. (Unlike me) was put-off the job because of the time & hassle of all those hard-to-reach engine cover bolts, hood clips, etc. etc.
I accept that 14 minutes is a long time to wait for oil to flow-in, but I VERY much doubt if anyone could detach the back edge of the hood, remove carpet and insulation, undo 10 bolts and complete the other tasks AND fill the oil via the Main oil-fill hole in anything like 14 minutes! Not to mention all the time & work to put the engine cover etc. back.
It also makes me wonder if some of the tales of ultra-slow oil refill via the Aux port (as in photo above) were as a result of leaving the dipstick in-situ???
Call me a smart-arse if you must, but I am the one who has saved myself a lot of time and (probably) grief!
