I have a question about oil coolers and temperature gauges.
I took my std 1.8 MGF to a track day and drove it hard. The oil temperature gauge was reading 170-180 degrees. Firstly how accurate is the gauge?
Regardless of how accurate it is I have decided to fit an oil cooler before my next trackday.
Did any of the MGF/TFs come with an oil cooler as standard? If so what model and what parts would you need to retro fit it to a standard 1.8?
Where is the oil coller located? Obviously the best place for cooling would be at the front but then you have a very long pipe run which I am concerned could lead to pressure drop and starvation problems. Anyone have any info>
And lastly has anyone fitted or seen an aftermarket cooler kit? I believe Brown and Gammons do one but it is not clear where the cooler is mounted.
Shaf
Shaf
