Hi I have rover streetwise td it's a 2004 and the ns indicater bulb isn't working replaced with a new bulb still won't work tried wriggling the connector block still nothing os indicate and other cluster lights working okay when I turn the stalk the ns indicator flashes rapidly could it be a relay or a fuse but I doubt I would have the ns front indicate and side indicater working if this was the case i had the loom checked as it runs over the tailgate and that's okay as common to break there any help would be brilliant cheers
