You need to know then each time you disconnect car battery you need to make resync process with ALL your fobs to the alarm system. This means you need to press unlock button 4-5 times, not too quick but also no too slow. Each time you disconnect car battery ALL your fobs lost sync and cannot be used without a resync.
Your horn came on as soon as you connected car battery because your car was locked and alarm armed when you took your car battery forbrecharge. To silence the hirns you need to press 4-5 times unlock button on your fob, first to resync the fobs, then to silence the horn.
Windows, wipers, erc start working is most probably bad earth connection. At this moment I do not have diagrams at me but I would check earth connections around car battery to panel since that one was last disturbed while you were removing your car battery.
