Afternoon - I have just bought a ZT cdti 131+ Saloon, anyone got any tips on what I should look out for? maintenance etc?.
If you have a wee search in this forum using the words MAF or MAFAM or Roverron (rover ron) I think you will find plenty stuff to give you some food for thought.
How many miles has it done?
Maf are prone to fail easy to diagnose though
Tuning boxes and air intake mods are a must have
Check fluid level in Clutch resevoir
Inspect the backside of the rear disks for excess wear
Listen for gurgling noises in the Aircon (might need a regas)
Check the cooling fans go in to Jet Turbine mode when AC is turned on
If it is a saloon check where the boot lid closes against the rear window seal if it is touching adjust the hinges and touch up the damaged paint before rust gets a hold
Other than that just drive it
